Fan Clutch???'s
dickeymoore
924
Atlanta,Georgia
I need a fan clutch for my 1988 Monte Carlo SS 305 engine and was wondering what is a good brand and part number for a fan clutch, I was thinking about the Hayden 2747 and are there any fan cluches that are made in the USA?Thanks
bracketchev1221
1,421
1,665
I'd have to look for numbers but I've had good luck using the Hayden clutches. I've used 3 on my cars and the fans.
79 USA 1
1,065
2,040
Cheektowaga, New York
The Hayden 2747 is the unit I have in my 88 Super Sport and works perfect.
In my 79 Monte Carlo I have a Hayden 2797 severe duty unit that was left from my El Camino. Never had any issues with Hayden fan clutches.
8,230
17,693
Good choice. THe 2797 is 3" shorter for use with fatter radiators. Other than that, I believe they're the same as the 2747. Both should work fine whichever you choose.
79 USA 1
1,065
2,040
Personally I put a drop of BLUE Loctite which is service removable.
8,230
17,693
studs with lockwashers under the nuts is how the factory did it. If they're in good shape, they'll do you just fine. Blue loctite is optional, but I have done it the old fashioned way without loctite and never had one come loose.
