finally selling
Or you could have gone and bought a line with fittings already on it, bent it and installed it in the time you have been jacking around trying to flare and rig the rusty line. Have you considered that if the line corroded to the point of a leak, the entire length of it is suspect? Many times steel brake line rusts from the inside out, since in this country, almost no one ever changes the brake fluid (DOT3 and DOT4 absorb water, BTW). Same reason I won't use an open container of brake fluid.Even today, people are religious about changing engine oil, but almost never change brake fluid.
Honestly, your story is all over the place....selling it, keeping it, have a buyer, going to keep it.....I'm worn out trying to follow this.
You should ask lilbowtie about resale on clean non-"image" cars. Personally, I don't see a red on red regal bringing $5K , unless you find a buyer that thinks 22K miles means it's the same as if it were 2 years old with that mileage. We all know that sitting most of it's life is not really good for the car. There will be plenty of worn-out parts on it due to age, not mileage.
But I do sincerely hope you find a buyer that appreciates it for what it is, since it seems that you are not in a position to really devote a lot of resources to it.
And when you say that i would have no problems if i bought a line with fittings, it dosn't make sense because i did buy brake line and i bought fittings, the problem was with the flaring tool i was using because it was leaking on both ends with the nicopp lines, stock lines, and i even tried stainless steel lines. it was due to my flaring tool being trash. im not dumb, if the line was leaky because it is rusty, i would have replaced the whole thing. plus like i said before, i cant really get under this car to replace the whole line because of my jack which makes repairing the line at the spot i need it the best option. the harbor freight jack is around 100$ plus 2 jack stands around 45$ just to get under the car, or i could just repair the small 4" section with the jack and stands which i have that i dont trust my life with, i wouldnt need to get under the car.
and im not saying your wrong, if i were to do this again i would replace the whole line from the start. but put yourself in my shoes, at the time it was the best option to try and fix that line and spend very little money on it instead of just buying all of the tools outright, but im still learning and i am all self taught.
Buy line with fittings already on it like this
Long enough to go from hose to prop valve.
Plus I have very little passion for this car because its so heavy, has little power and you can get Japanese cars for so much cheaper and with so much better performance.
It sounds like selling it is the right move for you.
I myself like the uniqueness of having a car that most people don't see very often, your car will provide a great foundation to build upon but it takes a vision and the right owner to make it happen.
Good Luck with your sale.
In my opinion, patching a brake line (or any safety item) is not the best option, but as I said, that's my opinion.
I was going to stay out of this one but since my name got brought up I'll give my 2 cents. As 8485 brought it up, before you go any further - see if you can open the bleeders on all the wheels. I'm guessing your going to be disappointed and have yet a bigger problem yet on your hands. The new high copper brake line is god sent and there is a learning curve to double flaring - you know how people you asked for advice feel about compression fitting. As far as $5,000 you might have it for a while. I sold a 1981 Regal w/ 21,000 mi's and got $3,600 - I sold a 81 Grand Prix LJ w/ 53,000 mi and got $3500 and both cars were beautiful and took a year to sell - certainly didn't get asking $$. I currently have an 81 Monte that I would let go for $3000
Reactions: Texas82GP
I feel I should say that I'm not trying to bust your balls, just trying to prompt you to think about possible other options or methods before making a decision. I guess in a way you could say we (myself and the other posters)are trying to give you an education based on years of collective experience. Many of us do this for a living, and may have insight into aspects that the relatively inexperienced do not.
Again, best of luck with whatever route you choose, and hope the Regal winds up in loving hands.
View attachment 59867 View attachment 59868
Sorry lilbowtie, I thought he needed to hear it from someone who knows well the market for BOP cars that aren't turbo cars, Hurst/442s or GP 2+2s
