You are playing the soundtrack for my Monte.
Not much of an upgrade, IMO. Only 15HP over the stock HO305 rating.
Yes, you can make up to 260 with it, but not as delivered.
Wow that is what I want. But I'll have to let a shop do it I suppose. Can it be done for 5k?I don't know what your mechanical skills or budget are but if you can assemble a long block I went with this from Tri Star for my budget build Regal project.
355 Chevy Crate Engine (Shortblock)
•4 bolt main block •9.5:1 compression ratio (with 64cc cylinder heads) This 355 Chevy engine is ideal for a shortblock on a budget. Tri Star Chevy short block crate engines are CNC blueprinted and machined to ensure accurate fitting. Give your high performance crate engine new life with this...www.tristarengines.com
And then added a set of these aluminum heads along with a hydraulic roller cam and should be at around the 325-350 HP range.
SBC CHEVY 350 383 406 NKB-200cc ALUMINUM HEADS 68cc STRAIGHT PLUG NKB-274-68cc | eBay
United States. Alloy +B4: H16. List of Standard Alloy Characteristics. and lighting components for aircraft. flat tappet and a hyd roller cam, then it would be too much for the hydr. flat tappet cam, and create a wear issue.rover.ebay.com
I shopped around for the best prices for name brand rockers, pushrods etc blasted a used RPM air gap intake and have a refurbished Holley 670 and this thing runs great.
