Recommendations are fine, but do we gotta be a complete dicks and sarcastic *ssh*les about it ?...that's all I'm saying...🤷🏾♂You 'gotta have some wiggle room here. If you only got an answer to your EXACT question....
You wouldn't have gotten the recommendation of where the fan should be & to actually measure your parts to be sure on what spacer is right for you.
You wouldn't have found out about the recommendation of flex fans not being used in plastic shroud apps.
You also wouldn't have learned about your accessory system being a reverse rotation.
We could have said 'yes' that's the right spacer in response to your question because technically you don't need a spacer if you're not worried about it working correctly.
Would you be ok if it didn't work because it wasn't compatible w/your other parts? These details make a difference & require more discussion. In the added discussions, people will share their insight. Take & do w/that insight what you will but don't complain about it.
Case in point...Well, his threads get clicks. Hope GP403 is enjoying the revenue.
I love you.
Yes, an answer I acknowledged and spoke of already...you due realize that right ? While your counting the number of posts I make, did you count that ? Narcissist always need an audience...just walk out on your own, no need to gather an army to take with you.Do you realize that you quoted me reminding you, with specific post, that your original question has been answered? Others have answered your question too. On behalf of myself and any other narcissists that have taken time out of their busy lives to walk you through all of your issues, you're welcome.
Reactor 4. April 26 1986.Now, all B.S. aside...
I've canceled the order on the fan because it is a standard rotation, and by the setup I have it won't work...
For clarity, what damage is caused if the wrong fan is installed and ran ?
Not sure if I am repeating anything. just replying to the quoted question.I've canceled the order on the fan because it is a standard rotation, and by the setup I have it won't work...
Fan blades in the wrong direction & turning backwards won't work as well to pull the air through the radiator. You're cooling system will likely struggle to cool.Now, all B.S. aside...
