I seen a video on line that had a 350 Chevy on the dyno. They tried all types of fans and the worst power loss was 30 hp and it was a mechanical fan. The electric fan used up 4 hp. I do not remember the link.I dont think I understand. You're saying you gain 20 to 30 by swapping to electric?
There is no power to be gained with different types of fans. They only provide a parasitic loss from having to slice through the air. According to engine masters video posted a little while ago, a stock clutch fan only takes 14hp. You'll never feel that driving around.
Sorry 2+2? How did you solve your heating issues?That is 14 HP nearly FREEWHEELING. Fulling locked up (behind a Hot radiator) its a lot more than than that. When my 2+2 was having high speed overheating issues and we were still using a clutching fan, the car sounded like a P-51 Mustang going by. It was probably more like 50 HP @ 5500 RPM than 14 HP.
What are those off of? Do they actually last?+
= less than $40 for a "controller".![]()
I actually had a temp switch fail, twice. It's been good so far. I teed a female spade into the relay trigger, and have a male screwed to the firewall. That way, I can run the fans manually without the thermo switch.[
A temp switch grounds the 86/85 circuit on the relay and turns on the fan. Both should be good for 100's of thousands of cycles. If the relays fails, unplug it and plug in another. They are only $4.
Does anybody ever consider the current draw from an E- fan introducing parasitic resistance to the alternator and belt drive(s)? An old school mechanic and good friend introduced that theory to me, yet I've never seen it measured. A fan is a motor, and can draw substantial amperage...
I was referring to the current draw as if it actually creates resistance on the drive belts like a clutch fan would. Can anybody answer if an alternator spinning at let's say 5k rpms with a 100 amp load on it creates more drag than if there was a 10 amp load? Or do alternators spin just as freely with a large current draw as they would without?
