floor pans for the g body cars
Not sure if you can buy that brace or not(?) I just cut mine out and reused it. And you will have to replace the other seat mounting brackets as well-or reuse them( I used new ones for that).
FYI.If you decide to reuse that brace and to make it easier to reinstall later. Cut through the tops of the brace(where it is spot welded to the inside of the rocker area)leaving the tops there,so when you put it back in you'll know exactly(sp) where it needs to go. Also helps to find the spot to replace the front seat mounting brackets as well. Hope all this makes sence,lol.
If you click on my 2nd picture you can see what I mean. The tops of the brace are still there.
thanks there in d nile,think you could get me some pics via pm showing just what your talking about(cutting top parts?) thanks again,want to get the brace out possibly today/tomarrow.how much was the whole floor panel you used,and from who again? thanks you d man!
Heres a couple of pics. You can see where its welded across the top.
awesome!!! now that helps out tremendously!!! gonna cut out the center bidge piece tomarrow and get it cleaned and ready,along with the rest of the rot, the rest go over with a weld buffing pad on the grinder ad treat it with a dose of por-15.then board up till the spring till my lil bro's finances get in order(just got part time job)as he is buying the floor,and ill be performing the surgery.as long as he,as promised gets his grades up!!! :wink: so thats the deal.thank you again for the informative pics and time.i come across monte parts on a regular basis,and if i can help you out wth something inparicular,dont hesitate to pm me with your needs.much abliged :!:
fraido2002 said:
In D nile do you have any more pics of the floor pan replacement, I am thinking of using the goodmark pan and am curious how well it fit and looks after your done.
I'll see what I can come up with....
Thats all I really have for now,I haven't done much more as of lately. But it fit very very good and I wouldn't have a problem using another one.
