I got a chance to replace the fuel pump this afternoon. Does anyone have any pictures of the gas vent line ran to a filter ?
Have you had a chance to test it since replacing the fuel pump and fuel filter?
Its not running at 220 the hand sits about an half inch before 220Other have said it, but sounds exactly like Vapor Lock/fuel boiling at the engine. 220 is WAY too hot for any non race engine. 200 max is where engines like to be. 180-190 is optimal. Check your fan clutch, fan, cooling system and thermostat. If that doesn't solve it, at least you wont be on the bring of baking your engine to death.
I crawled under the car seen both fuel lines what do u guys use to cut line or should I just add breather to the line I have now
If it were me I would probably cut the vent line near the tank and install the filter back there, higher than the tank. I would use a tubing cutter to cut the line.
Ok I did see where i could remove the rubber line and just replace it with a breather filter. When I find some money to throw into one of those little filters ill get one. I seen some for around 11 bucks online. Do you know if this can be picked up locally for cheap?
