I have a 1979 Chevy Malibu Landau and I'm noticing water dripping from the bottom of the door where it closes at the rocker panel is there a drainage system on these doors to let water out that get in like from washing the car?
Yep there are drain holes
They are tiny, clog up easy and will "seal" up if you painted the doors
maybe a chunk of rust is covering up the hole
pull the panel and stick one of those telescoping magnet down there
Every year or two I crawl under and spray each drain hole with a generous dose Fluid Film to hopefully keep them from clogging .
And also to hopefully help keep the rust at bay ...
Guy
