G body doors drainage
dickeymoore
924
Atlanta,Georgia
I have a 1979 Chevy Malibu Landau and I'm noticing water dripping from the bottom of the door where it closes at the rocker panel is there a drainage system on these doors to let water out that get in like from washing the car?
GuysMonteSS
1,449
1,542
Kentville,Nova Scotia,Canada
I believe that there are drain holes in the bottoms of the doors.
Just get underneath and have a look.
Guy
19,992
Yep there are drain holes
They are tiny, clog up easy and will "seal" up if you painted the doors
GuysMonteSS
1,449
1,542
Every year or two I crawl under and spray each drain hole with a generous dose Fluid Film to hopefully keep them from clogging .
And also to hopefully help keep the rust at bay ...
Guy
19,992
maybe a chunk of rust is covering up the hole
pull the panel and stick one of those telescoping magnet down there
ed1948
1,286
1,613
Quinte West, Ontario
In the meantime spray a generous amount of WD40 into the drains to temporarily slow the rusting. Try flushing out with a garden hose spray before WD 40. When and if you decide to tackle the rust WD 40 will be easier to remove in prep of bodywork. If you use Fluid Film or an oil product you will have problems cleaning the area for painting. Fluid film is one of my preferred methods for rust control.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
Have this happen lots on my Malibu. Yes small drain holes in the bottom of the door.
First trip I took the car on in the rain, I must have had 3 gallons of water in the door after an hour of driving in heavy rain on the highway.
Nov 4, 2012
6,024
12,775
Guy
+1 for Fluid Film. Had my truck sprayed in the fall and it really does keep the rust at bay. I'll be spraying the truck again this fall.
