GASKET HELP
UCNSTARZ
7
Anyone have a holley street dominator on there chevrolet v6 with a holley 4360 "economizer" 4bbl. I cant seem to find a carb mounting gasket that will seal? Any help would be great. Itsva spreadbore set up. Thank you in advance.
Ribbedroof
4,904
7,012
Wellston, OK
Mr Gasket #56?
Which Chevy V6? 3.3, 3.8, 4.3?
Does the manifold have a spreadbore flange or square? Most Holley intakes are square flange, which will require an adapter to run a spreadbore carb.
images
UCNSTARZ
7
Mr Gasket #56?
images
Spreadbore intake
Spreadbore carburetor
3.8 chevrolet engine
Ribbedroof
4,904
7,012
Wellston, OK
Where is the issue?
Can you post a pic of the manifold flange?
There are about a dozen different base gaskets for spreadbore carbs, a pic of the flange would help select the correct one.
8,825
7,778
Was there actually an aftermarket intake available for the V6? I would assume it is a factory 4.3 intake, the same isn't it?
9,614
12,683
79 USA 1
1,065
2,039
Cheektowaga, New York
UCNSTARZ
7
I put the car together 27 years ago. Holley 4bbl intake and Carb
Speed-pro pistons 10.5
Sealed Power Cam and Lifters
3 angle valve job
TH350
And recently 4.10 posi
