I would love to do a 6speed auto.I'm in the early stages of 5.3/6L80e swap. How do I make the shifter work? I wanted to get a nicer holley aftermarket shifter but none of them seem to be explicitly 6 speed
Since I'm using a 4-speed with a 3-speed detent rooster comb (column shifter), I rely on 'feel' of the transmission detents other than PRNO (feel to put in D, L, 1).
I think you could get a floor shifter for a 4-speed auto, align the gates with the transmission detents for PRNOD, and forget about the lower gears, unless you can over-travel the floor shifter to get L,2 and 1.
Gotcha. I figured I’d have an issue with this but fortunately I have a friend who went to a mechanic school for college so hopefully he can help.I’m not a 6L80 officiado so ……. If you were using a normal 2,3 or 4 speed, then be aware that the shifters made for them move the cable the appropriate amount to move the shift lever to the correct position. I think it will take a fair amount of engineering to get a 4 speed shifter to work with a 6 speed. I’m not saying it can’t be done, but it will be difficult.
Personally, I wouldn’t consider a 6 speed for a hot street car considering a 4 speed with with a lockup converter is basically a 5 speed. And the ultra low 1st gear just isn’t needed in a car. My $.02, but I understand why people use them as well.
They did but it was by moving the lever into 'D' & the electronics (engine/trans computer) doing the shifting vs being able to manually select a gear like a 2-4 speed auto.Gotcha. I figured I’d have an issue with this but fortunately I have a friend who went to a mechanic school for college so hopefully he can help.
I’m pretty sure every 6l80 worked with a column shifter :/
Don't do ANYTHING at the moment. You have quite a bit of research, and then decisions to make first.So my 3.8 v6 just blew and I am deciding what to do. I can get a relatively cheap ls 6.0, but the computer is DBW. I do have a DBW pedal sitting here already, but am a little concerned with the difficulty level of mounting the pedal, but more so just the difficulty of doing all the ECU wiring. Realistically how difficult is it to install the ECU? I am a novice mechanic, but think I am smart enough to figure things out. My other idea was to run the LS with a carb. But I am trying to be budget conscious and with the cost of manifold, carb and ignition box it will add around $1200 or more to the project. Otherwise I could just get a SBC350 but they seem to cost more than a takeout LS.
There pros and cons to fuel injection, and to carb. What transmission will you be running? How will you be mounting the engine? Buying a Holley kit, ICT adapter plates, making your own, etc. What about the cooling system? If you go into this with no plan, you WILL be bit and spend more money and most likely buy some parts twice. Start reading, thej read some more. Then make a plan. Then read more. If you want easy, open up your checkbook and buy everything Holley and bolt it all together. If that's the case, plan on well over 7500 just in parts not including the engine.
