you're going to have to put a disclaimer on some of your posts....![]()
Im confused what seems to be the problem ? I’m just asking for help or advice so I can get my gbody runningMaybe we need to go back to blue font for sarcasm
Ok thank you I’ll check my grounds later appreciate the helpThe plug only fits one way if it is intact. What pontiacgp is saying is correct. Of the 2 wires in the plug, 1 is the "excite" wire and is tied to the "volts" light in the dash. The other is a "sense" wire for the regulator and just goes to the charge post. Ignition on should kick 12v+ to the "excite" wire.
I think you have a ground problem, though.
Do theses car have a ground going to alternator I notice mine doesn’t have a ground
The problem is: that's the exact opposite of how it's spoda work. Does the light go out if you unplug the 2 pin on the side while it's running? My take is this: the battery is crap- probably a shorted cell. New alternator goes in, battery kills alternator, light comes on. Yes, 14.5v is correct, BUT your battery should rest closer to 13.2-.8, not 12.75.Just an update
so ground is fine had a buddy of mine come help me and we noticed that when I first start the car the voltage battery light is off and only reads at 12.75 volts after I gas it abit the battery voltage light on dash comes on that’s when my alternator starts working and voltmeter reads 14.50
