GBOTM: June '12 Entries Thread
1st photo stock 305 other photo's are 350 with cam and head work
Here is my engine bay also, its sporting a ZZ4 crate hope you guys like it!
sbc 350, L98 aluminum heads, Hurricane intake, Holley 750, 81 GM dual electric fans with plastic rad bracket, fiberglass airbox, brake proportion valve and Line-Lock, factory braces, factory A/C delete, AND a security chain :wink:
This is an LS1 derivative called LQ9 it is a 6.0 liter from an Escalade. I put a Edelbrock Performer RPM on it with a dual feed Holley Street Avenger. Not much chrome, but it is clean.
Mine took a month cause it was my first and I wanted to take my time and do as much of the work myself as possible. I kept the efi on mine.
It wasnt so bad. But I did spend more $ the first time around. Major parts needed: wiring harness/ecu, engine adapter plates, fuel system updated for efi, exhaust, shorten driveshaft
