GBOTM: June '12 Entries Thread
factory look with color in the correct places
402 Big Block 9.5 : 1 Hydralic roller cam, lifters, and rockers. Forged pistons and balanced.
1904 Edelbrock 795 CFM Qjet Carb and Street Fighter HEI from MSD
Power steering, power brakes, 3 core radiator with factory shroud.
Solid alternator pulley and hand made fuel lines.
Dual snorkel air cleaner and A/C delete.
She isn't real flashy but it's the look I was going for. We may have a record number of entries this month. Keep em coming!!
Okay. That's it. I'm not even gonna try to decide anymore.
Everybody wins this month. :lol:
Here's my entry:
-427 BBC iron Merlin block
-12:25:1 compression TRW forged
-1970 LS5 square port closed chamber heads (-291's) extrude honed int and exh
-solid roller comp cams .634i .621e
-1.8 harland sharp rockers
-Team G dominator intake, single plane extrude honed
-holley 950HP carb 88 jets all around (on top of 4500/4150 adaptor)
-MSD dist. with digital 6 ignition
-manual steer box from S10 pickup
-manual 4 wheel disk master from corvette
-copper Summit radiator, dual elec. fans and elec. Weiand water pump (on separate switches)
-hooker super comp 2"headers
-home made hood scoop seal pan
Kevin
Blake442 said:
I'm not proud of the rags, but they do their job :lol:
It's a blast to drive...
What you might consider doing (ive done it on my other car) remove your rags from the breathers and the top 4 or 5 inch section on a pair of tube socks that have the elastic upper portion and use it around your breathers, it works well and is cleaner looking. Just my nickels worth. Nice engine bay, good job.
My engine is a custom build stroker. It started its life as a 350 Diesel Block. I have it bored and stroked to 434ci. It has 4.155 SBC pistons, BBC forged steel rods, it also has a 425BBO Crank shaft. It was all custom fitted by myself and I did all the machine work, boring and honeing myself.
It has a good size cam in it. I also have edelbrock cylinder heads, Comp Cams Ultra rockers arms, Holley single plane intake, Just installed a March serpentine pulley kit, and the new Fast EZ-EFI fuel injection. Its a real monster.
speedkills80 said:
26 entries so far...Can we get to 30?? Maybe even 35?
Keep them coming!! 😀
i dont encourage this. everytime we get a lot of entries, i have to pm GP403 and ask him to up the limit on the poll selections. Right now it is at 25 but we are already way past that.
