what's the exchange rate of f*ck-tons to imperial tonnes? is it the same rate as the loonie to the dollar? or is it the Grandpa Gustafson rate?Metric tonnes or imperial tons? Specificity matters.
where does a Buttload measure into all this?what's the exchange rate of f*ck-tons to imperial tonnes? is it the same rate as the loonie to the dollar? or is it the Grandpa Gustafson rate?
Buttload is the container, commonly holding a metric sh*t tonne.where does a Buttload measure into all this?
You learn the damnedest things on this form......Turns out a buttload is actually a thing.
How Much Is a "Buttload" of Wine? - Bright Cellars
People use "buttload" to mean a large amount, but how much is a "buttload" of wine? Get this: a "buttload of wine" is an actual measurement! Mind. Blown.www.brightcellars.com
Seriously. Lolis that a long sh*t tonne or a short sh*t tonne?
taking it further, I looked at those pages.
"A buttload of wine is 126 gallons of wine"
"A tun is 2 butts"
knowing that pure water is 8lbs/gal, we do the simple math. 8x126=1008lbs
so a tun is 2 butts which would be 2016lbs. in other words, a ton.
...who knew?
(strictly speaking wine does not equal water in density, but I found claims of water being heavier and wine being heavier with 'math' to back it up. whatever. I just used a known approximate quantity and it still come comes out close either way)
did you tuck it in with a blanket? how many batteries you replaced since you arrived?Swapped the battery in the Colorado this morning. 6 years newer and 165 more CCAs should help wake it up in the morning. Should.
