GM 12 Bolt Rear End to G-Body
I have looked into it. Pricing for those is a lot especially with exchange, duty, shipping to Canada. And Grand National or any other G that ram the 8.5 from factory are not easy to come by up here either! I wish I could go with one of the made to fit rear ends!
I don't know what kind of power you have but the 8.2" I have cost me $600, it's a Eaton posi and had the 3.08 gears I like and it still has the original clutch packs. The 8.2" is good up to around 500 hp, I'm getting close to that so I might have to remove some stickers.
I say it everytime this topic comes up...
Even Chevy knows when they are beat......
Which is why the New COPO Camaro has a Ford 9 inch in it
I have a feeling that COPO is getting the rear ends from Moser....
Thats about the power im shooting for. Im just looking for anything that will hold up better than a 7.5 at this point! Lots of swap options for these cars.
And I am building a mid 90's Crown Vic 8.8 for my car. I should be well under a grand with all new internals when done 🙂 No special control arms, no c clip eliminators. Parts are super easy to come by and it will take the same abuse that a 12 bolt will take except I didn't have to spend a fortune for a bare housing.
yep there either Moser's or Strange's but they are Ford 9's design
Guys use 12 bolt rear ends from 68-72 novas/67-69 camaros. They are the right width but you need to modify it to fit coil spring set up. as for the "12 bolt" from the cutlass as I understand it has 12 bolts holding the cover on and bolt 10 bolts actually holding the ring gear to the carrier making it a 10 bolt rear end. Pop the cover off to verify.
Hey all, thought I would update this thread.
SO, i bit the bullet and went with a Ford 8.8 out of a 99 Exploder...
It has 3.73 gear ratio, Traction lock (Ford's posi), disc brakes, 5 lug and the beefier 31 spline axles.
This one was easier to come by than a Mustang or Crown Vic rear end, and has everything i am looking for stock.
Southside Machine Performance makes a complete swap kit with all the brackets and control arms that i will use.
I figure use that kit, new brakes, replace the clutches, brake lines, gear oil and whatever other misc. supplies I need i should be able to get this swap completed for right about 1000-1200 Canuck bucks with the cost of the whole rear end included.
That sounds like a pretty good deal to me.
Years ago when I bought my 9 inch from Forrest & Forrest Racing in Kitchener Ont I paid $ 1200.00 and had to supply my own center section,limited slip and brake shoes.
I will pass along a tip given to me by the gentleman that I got my center section and limited slip from,and he is a long time Ford guy.
Before you install those new clutches,soak them in a mixture of whatever gear oil you are going to use and a bottle of Ford Limited Slip Additive for at least overnight.I left mine to soak for a couple of days.
You will know it when you buy the genuine Ford stuff as it stinks like a skunk,even in a closed bottle,LOL
This tip works and will help your new clutches live a longer and happier life.
Be sure to let us know how you make out...
Guy
Guy
I think i made out alright for what i paid for the rear end and for what it will cost to have it all said and done sitting under the car!
And i have heard that the Ford LSA is just a horrible, putrid smelling liquid haha. Thank you for passing on that great bit of info. I was aware to soak them but I will let them bathe for a couple days now prior to install!
I will update this thread and try to take as many pictures and pass on whatever i find and learn doing this swap. (I will try my best at maybe doing a "How To" on it but there are some members on here who can write them up like they are from a magazine haha.)
I know the guys at SSM said as much tech support as needed so that will be a life saver come time as well. It might be sometime before i have all the parts ready but i will update come the time!
