GM 12 Bolt Rear End to G-Body
20,397
I have looked into it. Pricing for those is a lot especially with exchange, duty, shipping to Canada. And Grand National or any other G that ram the 8.5 from factory are not easy to come by up here either! I wish I could go with one of the made to fit rear ends!
I don't know what kind of power you have but the 8.2" I have cost me $600, it's a Eaton posi and had the 3.08 gears I like and it still has the original clutch packs. The 8.2" is good up to around 500 hp, I'm getting close to that so I might have to remove some stickers.
20,397
I say it everytime this topic comes up...
Even Chevy knows when they are beat......
Which is why the New COPO Camaro has a Ford 9 inch in it
I have a feeling that COPO is getting the rear ends from Moser....
abrodeur79
25
42
13
Edmonton, AB
Thats about the power im shooting for. Im just looking for anything that will hold up better than a 7.5 at this point! Lots of swap options for these cars.
gnvair
1,102
1,307
And I am building a mid 90's Crown Vic 8.8 for my car. I should be well under a grand with all new internals when done :) No special control arms, no c clip eliminators. Parts are super easy to come by and it will take the same abuse that a 12 bolt will take except I didn't have to spend a fortune for a bare housing.
19,992
yep there either Moser's or Strange's but they are Ford 9's design
Shmiv
11
11
Guys use 12 bolt rear ends from 68-72 novas/67-69 camaros. They are the right width but you need to modify it to fit coil spring set up. as for the "12 bolt" from the cutlass as I understand it has 12 bolts holding the cover on and bolt 10 bolts actually holding the ring gear to the carrier making it a 10 bolt rear end. Pop the cover off to verify.
abrodeur79
25
42
13
Edmonton, AB
Hey all, thought I would update this thread.
SO, i bit the bullet and went with a Ford 8.8 out of a 99 Exploder...
It has 3.73 gear ratio, Traction lock (Ford's posi), disc brakes, 5 lug and the beefier 31 spline axles.
This one was easier to come by than a Mustang or Crown Vic rear end, and has everything i am looking for stock.
Southside Machine Performance makes a complete swap kit with all the brackets and control arms that i will use.
I figure use that kit, new brakes, replace the clutches, brake lines, gear oil and whatever other misc. supplies I need i should be able to get this swap completed for right about 1000-1200 Canuck bucks with the cost of the whole rear end included.
GuysMonteSS
1,449
1,542
Kentville,Nova Scotia,Canada
That sounds like a pretty good deal to me.
Years ago when I bought my 9 inch from Forrest & Forrest Racing in Kitchener Ont I paid $ 1200.00 and had to supply my own center section,limited slip and brake shoes.
I will pass along a tip given to me by the gentleman that I got my center section and limited slip from,and he is a long time Ford guy.
Before you install those new clutches,soak them in a mixture of whatever gear oil you are going to use and a bottle of Ford Limited Slip Additive for at least overnight.I left mine to soak for a couple of days.
You will know it when you buy the genuine Ford stuff as it stinks like a skunk,even in a closed bottle,LOL
This tip works and will help your new clutches live a longer and happier life.
Be sure to let us know how you make out...
Guy
abrodeur79
25
42
13
Edmonton, AB
Guy
I think i made out alright for what i paid for the rear end and for what it will cost to have it all said and done sitting under the car!
And i have heard that the Ford LSA is just a horrible, putrid smelling liquid haha. Thank you for passing on that great bit of info. I was aware to soak them but I will let them bathe for a couple days now prior to install!
I will update this thread and try to take as many pictures and pass on whatever i find and learn doing this swap. (I will try my best at maybe doing a "How To" on it but there are some members on here who can write them up like they are from a magazine haha.)
I know the guys at SSM said as much tech support as needed so that will be a life saver come time as well. It might be sometime before i have all the parts ready but i will update come the time!
