Re: GNX2 Has Arrived(Feb. 23, 2011)
looks solid!
I say 86-7 GN or T-type drivetrain. A turbo LS would be cool of course.
looks solid!
3XBrownCutty said:looks solid!
dogshit said:What engine, hmnn what are your goals for the car? What do you really want to end up with & or how are you going to use the car? 400 sbc already in it for ease & bang for the buck it would be hard to replace. Did the Caddy swap as you can see in my photos and miss it dearly. LS series would be a strong consideration looking forward and at fuel costs. Again what is your goals or important to you? Limited mileage, nostalgia, crazy big block torque Caddy. Mileage, modern, latest car trend, LS.
Transmission? Drag car usually a three speed th350 or th400 depending on engine choice and output. Almost anything else in a gbody the best choice all things considered is usually the 200-4R. http://www.extremeautomatics.com
Edit Yea a GN drivetrain if you can find one reasonable can also be a great choice.
dogshit said:Surprised you sold your Buick it was cool and I'll bet fast and not yet even finished. 30 years of hot rodding the Buick 455 & Caddy 472/500 are my two favorite street car engines for the gbody. I sold my spare "still ran when pulled" 500 the other summer for $250. I had never run it just knew that I could turn in over by hand. The guy who bought it blocked it up in the back of his pick up had fuel & a battery and started it. I thought it would be rough after moving it around and not running for 4 years, nope after a little warm up it was smooth & had clean exhaust. I knew I shouldn't sell it then but such is life sometimes. He gave me asking price with no bartering after seeing it then we loaded it up.
Honestly going the stroker route is at least an extra $1,000 just in parts and is overkill in a gbody. The 4.3 stroke of a 500 makes LOTS of torque down in the low 2,000 rpm range right where you drive it.Even with a good bit of cam.
Plus the heads (as do all old v8s) already need work to allow her to breath deep and work toward her potential.
If I built a stroker it would be to a smaller BBMopar bearing size for the primary purpose of having an engine that likes and can take more rpm better. The smaller bearing can still easily take the load but does not make near the heat. Safe bore to match the stroke would end up with a 542ci and a need for worked aluminum heads in order to allow her to breath.
What year 500 and did it come from an Eldorado?
