New larger wheel installed. It's only 1" larger but makes quite a bit of difference to me. I also did a tie rod end adjustment to center the wheel and adjusted the play out of the steering box.
My center caps finally came in. Well, more accurately they'd be called spinners or knock-offs.
They were listed as NOS and when I opened the box they were packed in newspaper dated 1985. Been on the shelf awhile, I guess.
These weren't exactly the same as the set I had initially tried to order. I had to grind the outside of all four just a bit to get them to fit the center register of the wheels.
Then, on the front two, I needed to relieve just a bit to clear the hub of the rotors.
Since these towers were slightly shorter (shallower) than the original set I wanted, I had a clearance problem with the front dust caps. I ended up just removing them and ran a bead of RTV around the threads of the knockoffs to keep the grease off the wheels and the dirt and water out of the bearings. I think they make the wheels look wider/deeper. Feedback, both positive and negative, is welcome. Here's the finished product...
