Griffin Radiator Home made brackets/ top cover plate
9,619
12,713
I just replaced my old Griffen radiator with a new Griffen in July from Summit and I paid $246 then. They are now $267
http://www.summitracing.com/parts/gri-8-00010/overview/
It has 2 x 1.25" tubes and is about as wide and tall as you can go in a Gbody.
It comes with a petcock on lower drivers side and the water neck is machined and uses a AN fitting.
Also it is all aluminum construction my old one has the epoxy.
Mine I polished before installing and I am using my old Griffen for a future project.
With the 26" core they also fit the Intrepid dual electric fans almost perfectly.
Fox80
563
9
16
Jamestown NY
I have not really bought anything from Summit but you can get a single row for $175 and dual row for $210 from Speedway Motors any width you want. Thanks for the heads up on Summits apparently high prices
565 that is the radiator that is probably a better choice for the street, spending the extra couple bucks to have a drain would make life easier down the road. Do you recall who makes your coolant catch can?
9,619
12,713
I did not see this radiator on Speedways site Griffen part# 8-00010 this one has 2 x 1.25" tubes and is 31.25" x 18.62"
I think the extra money goes toward tubing thickness as most two row radiators only come with 1" tubes. I would be curious to see Speedways price on this exact radiator.
As far as the aluminum recovery can it is a Canton Racing part# 80-201 I also polished this before installing it comes in a brushed/satin finish.
Fox80
563
9
16
Jamestown NY
Speedway wouldn't have your radiator, I was referring to the price quote the OP gave for his
skulledmonte84
426
6
near Clearfield pa
565bbchevy believe it or not your one youtube video i watch,started this whole cover project lol you got very good taste :) mine is the Griffin Radiators 1-86272-X the guy i bought if from told me his buddy paid for around 400.00 for it 4 years ago.an used it 3 races hell it looked brand new inside, I like that overflow tank,whats one like that run $ i seen these canton over flow tanks on ebay for 170.00
skulledmonte84
426
6
near Clearfield pa
i don't have no close up shots but here's the radiator/engine bay
skulledmonte84
426
6
near Clearfield pa
more shots i have youtube vids of it,Everything needs to be cleaned an polished
9,619
12,713
If that is the actual number those come with 2 x 1-1/2" tubes which makes your core thicker than what I am using to cool my 565 big block.
You will definitely not have any overheating issues with that. To verify it is the X series just measure the thickness of the core.
The radiator in my videos is my old Griffen for that I made the cover plate for, my new one came with a flat top and smooth tanks so I just polished the entire radiator.
The recovery can I wanted next to the radiator like my old plastic one so I bought a similar style to fit in it's place and made aluminum brackets to mount it to the core support and of coarse I polished those too.
skulledmonte84
426
6
near Clearfield pa
It's 3" thick not sure about X series though, I thought about just going with a 2x13'' Polished Aluminum Universal Radiator Overflow Tank but not sure how id mount it,iv seen some pics on here of them.some i just don't care for the way there installed Now what u got is nice.it's still saying (0 new messages) i got to keeping clicking view post to see if anyone reply an not getting emails either WTF
9,619
12,713
This is my old plastic recovery tank with my old radiator, since the new radiator came with a AN for the overflow I wanted to make use of having a braided line with fittings on both ends which I can't do on the plastic one.
