I wouldn't be keen to swap valve bodies. When I swapped in the 200r4 and 3.73 rear into my car ( from an SS ) if shifted well but "factory" soft like the high mileage trans it was. I knew it was on borrowed time behind the 350. When I promptly cooked 2nd gear in the trans from the SS I left it in the car so I could limp it around. I had a spare trans from a friends 442 ( he went stick ) and had that build up. To be fair we put a healthy bunch of parts in it during the rebuild. And the trans tech spent a lot of time with the steels and friction disks checking the clutch pack with an air line until he got the right "feel" that he was looking for. When we put that rebuilt trans from the 442 in my car I found the shifts were happening sooner and much much firmer than the trans from the SS. Adjustment of the TV cable would either make the trans shift sooner or on the other end if we set it to delay the shifts they were too harsh. Trying to remedy the issue we swapped the VB from the SS into the 442 trans and it made the issues even worse. In the end we monkied with the governor to get it better ( see link below ). It still feels like it shifts too soon at part throttle but holds to just shy of 6k when you get into it so I am happy. But if I did it over again I would have rebuild the trans from the SS to begin with.
http://garage.grumpysperformance.com/index.php?threads/200r4-mod-info.7116/
That what I was thinking. I'm afraid if I take the VB from the SS and stick it in my current transmission I'll have a real Frankenstein transmission and if it doesn't work right no one will be able to help me. I thinking as an option, It might be cheapest and easiest if I switch the rear end to 3:23's(tallest gear the series 3 carrier I now have can handle). Yeah I'll have just wasted money on brand new 3:73's, but maybe I can sell them and make a few bucks back.
