Hard starting with headlights on?
MrSony
6,831
6,741
Des Moines, Iowa
Yep. Starts fine with em off. Leave em on (such as in a drive thru) and if I shut the car off it lags bad and almost wont turn over sometimes. Turn the lights off it pops right off. I know I need new headlights, one has water in it, 2 are original. Could that be the issue?
MrSony
6,831
6,741
Des Moines, Iowa
Battery is a year old. All grounds are clean and accounted for. Negative cable is new, positive is not.
MrSony
6,831
6,741
Des Moines, Iowa
I know for a fact the positive cable is structurally sound, it's just old. I've been meaning to replace it but I want to keep it side post and aftermarket side post cables fit like sh*t at the battery. Bolts too short, rubber too thick, etc.
565bbchevy
9,614
12,683
Michigan
I have seen factory cables that appear to be "structurally sound" but end up being all corroded on the inside, I am betting a new positive cable will fix the issue but still replace your fishbowl headlights.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Dont start it with the lights on
no more problem
  • Winner
Reactions: 5 users
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
If he puts a worm gear on the 7 blade maybe he can turn his regal into a helicopter!
