EL CAMINO Has anyone used different manifolds with the Holley Ls swap motor mounts
  • Thread starter mikeselcamino1984
  • Start date
M
mikeselcamino1984
n00b
Jun 4, 2019
2
I have bought the Holley G-body swap pan, g-body swap motor mounts, and the transmission crossmember to do my 5.3/4l80E swap in my 84 ss el camino. Has anyone used any different manifolds or ls swap headers with the Holley parts and if so, what did you use? I don't really want to buy the Holley exhaust parts, but if I have to, I will. Just seeing what everyone has used with the Holley parts.
Thread starter Similar threads Forum Replies Date
R Has Anyone Seen This Malibu??? General Discussion 0
82HellCamino Has anyone tried EZ Air Ride suspension kit? Frame / Chassis / Suspension / Steering 2
7 New Pearl Jam Video has a later model G body Cutlass at the beginning... Photos, Videos, etc. 4
pontiacgp GBodyForum Has Competition OFF TOPIC 24
pagrunt Free coloring book for little & big kids-has a GNX too General Discussion 3
pagrunt OLDS Would you pay $400 for this-it has a certificate of authenticity Oldsmobile Cutlass / 442 / Hurst/Olds 14
JAMCAR223 Has anybody been successful in keeping the paint from peeling on Olds exhaust ports?? General Discussion 20
MrSony Neil Peart has died. OFF TOPIC 14
pontiacgp Canada Post Has A Time Machine OFF TOPIC 5
39F Bell housing has a slight hole in it now Transmission / Rear End / Driveline 18
MCCAY EL CAMINO Wife's dream car is an El Camino, now she has one. New Users 3
69hurstolds 442 My Dealer Ad License Plate Has Seen Better Days Restoration 9
MalibuDavyou5 Anyone else under suspicion that Walmart doesn't change Oil Filters? OFF TOPIC 15
S Anyone used Fuel Injector Connection? General Discussion 2
azmusclecar Does anyone know the difference between a DR31 and a DR32 COIL IN CAP for my 1979 OLds 350? Electrical / Ignition / Starting 5
39F 4 wheeling anyone? Non-G Projects 28
H does anyone know if these irocs will fit? General Discussion 0
olds307 and 403 Anyone ever have a temp gauge read really high? Cooling / Heating / AC 12
gnvair Does anyone have a picture of the stock radio brackets for a 86-88 Monte Carlo (or El Camino) Chevrolet Monte Carlo / SS / Malibu 7
rogus Can anyone reccomend a good (comprehensive) shop manual... General Discussion 14
69hurstolds Anyone Finish Their 2020 U.S. Census Online? OFF TOPIC 31
565bbchevy Anyone ever seen this Regal? General Discussion 13
82HellCamino Anyone running a Big Block and have heater only? Cooling / Heating / AC 5
old80cs Anyone been to the Newport (RI) Car Museum? General Discussion 1
joesregalproject Facebook Creeping Anyone Else Out? General Discussion 74
RecklessRegal Anyone have a source for anodizing? General Discussion 5
old80cs CUTLASS Anyone used these trim rings on factory 15” painted ralley wheel? Wheels / Tires / Brakes 5
grandamman Penetrol Anyone here use it? General Discussion 5
Rigo’s87 Does anyone know what this is called? General Discussion 2
C PONTIAC Anyone here with 3rd gen f-bodies? General Discussion 6
69hurstolds CUTLASS SOLD-Anyone needing NOS 1980 Calais/442 grilles? Restoration 12
gnvair Can anyone definitively say that the front lower control arms from an S10 will work on a 78-88 A/G body?; Frame / Chassis / Suspension / Steering 22
marcar1993 Anyone run wood heat in their shop/home? General Discussion 9
TURNA Anyone going on a Junkyard run??? General Discussion 26
565bbchevy Anyone ever wrap a chrome bumper? General Discussion 2
1-sic-83 Anyone seen one of these? General Discussion 10
joesregalproject Anyone use one of these aftermarket heat only boxes? Cooling / Heating / AC 14
gnvair Anyone see the wrecked Royal Knight 4 speed El Camino on Facebook? General Discussion 21
olds307 and 403 Anyone know the thread size for the thread in ports to the left and right of the thermostat on an Olds Performer or RPM intake? Oldsmobile Cutlass / 442 / Hurst/Olds 8
C MALIBU Anyone running 17 in the front and 15 in the rear ? Wheels / Tires / Brakes 5
gnvair Does anyone have an untouched 78-79 Malibu, El Camino or Monte Carlo with air conditioning? I need a picture of the capillary switch mounting Chevrolet Monte Carlo / SS / Malibu 9
joesregalproject Anyone going to Canfield this weekend? Events 6
TURNA Hotchkis front springs.........anyone......? General Discussion 3
D Setting window in weather striping on driver door is there anyone who does ajustments New Users 1
TURNA Anyone have a "BOOK VALUE" Book OFF TOPIC 15
HAFROD Anyone know converter stall speed on 2004R? Monte SS vs turbo Buick Transmission / Rear End / Driveline 3
D Used RUST FREE suspension and brake parts MOST R FREE Frame / Chassis / Suspension / Steering 4
Similar threads
