headlight conversion kits
G_Body_Enthusiast
1,056
16
38
Louisville, kentucky
if i run HIDs i only need 2. i hardly ever used high beams to begin with and with HIDs i doubt id ever need them at all.
that being said i think they have a kit that allows you to run a H4 hi/lo bulb, effectively giving you a lo and high beam but in one bulb. rendering the original high beams useless. which is ok by me, like i said, i hardly use them to begin with.
i'll have to double check that though.
yup they have bi-xenon bulb kits. plenty of them too. but look at what plugs into the housing, it looks bigger than a regular bulb...or the pics are lying and they fit in just like a regular H4 halogen bulb.
now im wondering which H4's these are wired for, the H4 halogen bulb or the H4 style sealed beam like our original headlights. i bet i'd have to pull the pins out if possible and move them around. not a huge deal i guess but knowing my luck i'll break them.
20,413
the bi-xenon bulbs fit the housing....I have 2 of the bi-xenion and 2 single xenon in my vehicle..
85_SS
683
Ontario, Canada
I upgraded to H4's last winter - as mentioned above, H4's will be higher wattage and you will likely have to upgrade your harness to run them. Some have gotten away with the stock wiring, but most run into problems with the brights on (like I did) with the breaker in the headlight switch cycling on and off. Here's a thread on mcss.com with lots of info on the subject:
http://www.montecarloss.com/community/u ... Post523368
Here' some pics of mine (these were before the harness upgrade, so they are even brighter now):
G_Body_Enthusiast
1,056
16
38
thats why if i do switch over i'll be using a kit with relays, they take the load off the wiring so your switch doesnt get too hot. thats why they use them for everything now, they take the loads off the switches and wiring.
andrewmp6
487
4
My truck has the same kinda head lights.I use the glass style h4 off ebay with the relay kit.The plastic ones suck mine i had before fogged up and you need a relay or could have a fire.I just wonder how hard would it to get a hid kit with them.
G_Body_Enthusiast
1,056
16
38
its rather easy to get a HID kit with a relay. you can find them on ebay all day long. i did a search for "HID H4 bixenon" because im figuring instead of using all 4 headlights i could just use two and have hi/lo's in the same housing. that way i only need a pair of housings, not 4. saves me a little change in the process.
i may not do this for some time but this is probably the way i would go.
85_SS
683
Ontario, Canada
The kits also provide a much better circuit and will usually offer brighter lights even on a stock system due to being connected directly to the battery rather than snaking through the cabin and engine compartment. Kind of surprising the factory headlights didn't operate off of relays really...
Fire technically shouldn't be an issue - the breaker in the headlight switch should trip before any wiring gets too hot to cause any damage... BUT, when you are talking about wiring that's nearly 25yo, it's better safe than sorry. I picked up my relay kit on ebay for ~$10 - cheap insurance and a better setup in the end.
Lawfree
49
Not sure if we are talking true HID lighting with the Ballast/Starter units
or the "quasi" HID which are just HP H4 bulbs with the true HID "look"
The H4 bulbs have a three prong plug but the wires will have to be switched from what is used for the regular sealed beams. I would definitely run headlight relays on these High Output bulbs. I use a nice fused 2 circuit unit in a metal box from J. C. Whitney (believe it or not) and it's better quality than the the cheap Bosch type relays. In fact if you measure the voltage to you headlights (with or without the eng. running) you will see there is a large voltage drop by the time the power goes to the headlight switch in the dash and then back out to the headlight Harness. It was reading about 9.5 VDC on my 80' Cutlass before installing the relays. GM did this intentionally (brake tail/lights are the same way) to increase bulb life. Just adding the relay and some high quality Quartz Halogen sealed beams will make a huge improvemnet and keep you car legal too.
455cutt82
33
pcola fl
i was thinking of doing this on my 84 cutlass front end and was looking but could not find a dfinitive answer anyone got any help
patmckinneyracing
2,021
36
San Antonio, TX
I bought the same set up off ebay. They are called "projectors" and I only paid 30-40$ for them. I just plugged up the origional headlight harness and have not had a problem since. Definately is a helluva lot brighter than halogens and well worth the expenditure. These are not HID conversions, but come with the complete housing and bulbs and are well worth the price and can compare to an HID headlight. Also put a pair in our 1985 dodge d150 prospector, since it uses the exact same headlight as my malibu and they work just as great. I just opted for the blue lense, but make sure you don't get the housing that has the black coating on the inside, go with chrome. If you get the black ones, you won't see a thing.
