CUTLASS Headlights Are Not Working
Emhendo
May 20, 2019
54
6
Chicago Soufsidee
The switch turns on my tail lights, the tailights are fine.
But ALL FOUR of my headlights just mysteriously stopped working, and I'm confused as of how this could happen all at once.
One day I turned them on, they didn't work.. On my way to autozone for new bulbs, they just mysteriously cut on.
I cut my car off for the night. They haven't cut back on since... I been only daytime driving for almost 2 weeks and no matter what I try to do, they won't work.
I'm not sure which fuse is my headlights. Can somebody school me on the fuses and which fuse to install.
Does anybody have a diagram of the fuse box AND the wiring
I'm not sure if these headlights are designed to only cut on any night???
Can somebody help me dissect and diagnose the possibilities of this problem??
20,397
before you change bulbs why not check to see if you have power at the headlight plugs. Sounds like the headlight switch is the problem but you can check the switch with a multimeter. There is no fuse for the headlights, the switch itself has a thermal breaker switch.
Emhendo
May 20, 2019
54
6
Chicago Soufsidee
Yeah, I cleaned the grounds and I the terminals that go to the bulbs are "hot". So my wiring is fine..
Still no active headlights.
If it was the switch, wouldn't that mean my tail lights would not work either?? Because they work.
9,186
15,399
The tails have their own 20 amp fuse in the fuse box.
If you have power at the front, it's the bulbs. Yes, they can ALL go bad at once. You say you checked the grounds. They all go to a splice in the loom near the horn. Do yourself a favor and cut the puny 16ga leg off, and up it to 10 or 12ga on a clean connection on the fender.
Alternatively, your switch in the dash could be munged up; spray it out with some CRC contact cleaner.
5spdCab
1,190
1,989
Tukwila, Wa.
Welcome from Seattle, Wa.
pagrunt, and flemming442, have both given good advice, but just in case those options don't work, a third possibility could be simply a loose/broken wire that makes intermittent contact. As for all of the headlights going out at the same time, I would never have believed it if I had not experienced it myself once, so that is a definite a possibility.
20,397
the headlight switch has different circuits for the parking/tail lights and the headlights. Take the switch out and test it with a multimeter, you turn the headlights on and see if the circuit is open or closed, if it is open then the switch is the problem
