Haha
Hahaha. No. I knew better than that!I bet you left the battery hooked up when doing the starter, didn't ya, Sparky?
Can I just put those size fuses in there or do I need bigger wire now?You need 40A or 50A fuses.
Yeah 1 gauge wire if possible is good to use, I have it on my 88 CSC. I actually am feeding the alternator with a 4 gauge wire. Try a 25 or 30 amp fuse.Also I'm running a new 4ga which is the same as the old starter but its a tad bit longer than original. But after looking at the starter info I seen this diagram...looks like I should've used 2ga wire from the starter to battery? 5ft long cable.
Can I just add the bigger fuse in that 12ga wire or do I need a bigger gauge. And would the 4ga wire I'm using be the issue for the fuses blowing?Yeah 1 gauge wire if possible is good to use, I have it on my 88 CSC. I actually am feeding the alternator with a 4 gauge wire. Try a 25 or 30 amp fuse.
