I put a big block olds 425 in my 87 cutlass where a 307 used to be. For the most part it was a very simple straight forward swap. Couldn't have asked for a better first ever motor swap. But anyway one place that was a little tight was the right side valve cover and the ac/heater box on the firewall. Although it did fit without actually touching i did end up having to put in new pushrods and i was only able to get those rear ones out by cutting a hole in that box. It seams like the only thing i actually cut was an outer shell, no internal components. My question is will this cause the heating system to not work right? Do i need to find a way to patch that back up? I don't care about the ac i don't plan to set that up anytime soon. But i do care about the heat. Thanks
