I hope you mean safety wire, not wire ties!I had an eaton carrier and true track set up with all arp bolts. The ring gear was also wire tied. Anyway it broke 3 of the main cap bolts and put the carrier part way out the cover....
I cut the baffle plates out of the inside of the valve covers, I’m having issues finding the short polys, one set it 1.25 tall and the other is 1.10 tall, my other issue is I can barely get the passenger side valve cover on and off now as it is due to the heat/ac box. At one time I was going to hook the ac back up but I have decided to go another route since thenShort poly locks and dimple the oil baffles where they contact. It's a myth that they don't fit under stock covers.
You could go Vintage Air, which moves everything under the dash and still have A/C and have plenty of room for the passenger side rocker cover.I cut the baffle plates out of the inside of the valve covers, I’m having issues finding the short polys, one set it 1.25 tall and the other is 1.10 tall, my other issue is I can barely get the passenger side valve cover on and off now as it is due to the heat/ac box. At one time I was going to hook the ac back up but I have decided to go another route since then
Holy crap, what are the specs on your 455? An 8.5" built like that should be good for 500+ ft lbs. What stall are you running?I had an eaton carrier and true track set up with all arp bolts. The ring gear was also wire tied. Anyway it broke 3 of the main cap bolts and put the carrier part way out the cover....
Yes that’s exactly what I have been looking intoYou could go Vintage Air, which moves everything under the dash and still have A/C and have plenty of room for the passenger side rocker cover.
She’s stroked (forged crank)balanced rotating assembly .040 over bore, halo girdle, Engle cam, 11:1 cr. , zinc filled and full ported old school mondello heads ( pre 2002 era), 2in primary tube headers 3.5 collector, air gap duel plane intake with a quick fuel 830 mechanical secondaries, 32-3400 stall non lock up ,Holy crap, what are the specs on your 455? An 8.5" built like that should be good for 500+ ft lbs. What stall are you running?
