I wouldn't care what my track time was if I could pull the wheels of the line are guys using a trans brake
woody31 said:I am surprised no one has mentioned pinion angle,,mine works at a -3*
I run a D-75 compound Hoosier slick
on a wore out motor it ran low 14s high 13s..no spin no wheel hop,,,used g body elcamino rear springs with 2 inch lowering springs up front,,
woody31 said:i was replying to the o.p. smart *ss,,,and if that is a posi in there ,it is junk,,i saw only one wheel smoking,,you have a bad clutch pak in there or a cracked cone in the diff,,fix the rear end and get a good set of slicks,,and yes you can adjust pinion angle a lil bit,,send a p,m, if you want to know how,,
