Help Me Hook *Video* new link
What did you change?
Yeah i saw. Still spinning. If you can get your hands on a go pro or have someone at the line you can see better on whats going on
What kind of condition were the slicks in that you used?
Your car is still not fast enough to be spinning slicks like that.
That is not an insult to your car by any means. I just think there is something more to it like track prep (lack of) or the slicks were worn completely out.
With a good set of slicks your car, with stock suspension should transfer enough weight to hook. You are headed in the right direction now though.
The slicks are used but apprear in good condition im not sure how old they are. I tried doing a long burnont and that didnt help. I was hooking good after the tree but not on the initial launch
Do you drive through the burnout box or around it and back into it??? Also, try and let your burnout carry you most of the way to the staging beams instead of driving to the staging beams. Your tires won't pick up as much debris that way.
