Help me out 400 to 307
Swapping 400 to 307
  • Oldsmobile 307 to pontiac catalina 72
    Votes: 0 0.0%
  • Motor mounts
    Votes: 0 0.0%
  • Wiring
    Votes: 1 100.0%
  • Total voters
9,619
12,706
IMO if you want a wimpy underpowered engine you should look for a Pontiac 301 and it would be a direct swap.
That way when you get tired of being passed by old ladies you can get your 400 rebuilt and reinstall it with no issues.
ck80
5,743
9,123
A worn out cutlass 307 probably packs 1/3 the power and torque of the 400 done right.
If you insist on doing it, find the equivalent generation and body style of the Catalina that originally came with a SBO and take those mounts. Then save your originals for when you want to go back.
If you got rid of or destroyed the 400 somehow, find a 455. All poncho v8s were externally the same do get the cubes for that heavy lady
L92 OLDS
2,872
3,051
West Michigan
Kamloops cutlass
413
543
Kamloops bc
As someone who has ran a 307 and a 301in a Buick lesabre, I recommend against it
Way underpowered and there is no cool factor in holding up traffic or being afraid to pull onto a busy street in a lazy heap
Just my opinion, it’s free and it’s worth it 🙂
pontiac guy
582
843
Royse City, TX
I'll buy that 400 from you.
You need different motor mounts. Look at delta 88 for a donor. I'll also buy the Catalina from you because it deserves better than a 307 olds. PM me
8,827
7,783
I like the 307 but why would you do this? You need 73 through 90 frame mounts and the same for replacement mounts. A lot of work for 140 or 150 hp and 245 or 255 tq.
