Help with budget lowering
Is this ok for placement? Haven't seen any pics anywhere of where or where not the spring should sit in the control arm?
I would try to keep it lined up between the two drain holes on the "inner" part of that lca spring perch. Try to make sure it doesn't turn out as you slowly raise it back up. Also try to keep an eye to make sure the spring is seated up top. And be carefull.
Ok getting closer.. Trimming the moogs worked out.. Just took a bunch of trim install .... Remove etc.... Once you cut too much off they are trash. Ask me how I know... Seriously thinking about grabbing some coilovers for the front. I may just leave it as is..
Reactions: pontiacgp
