Help!!
20,397
Did you even read this?
And, I hope that's not the fuel system all over the place. That thing looks like a fire waiting to happen.
That is a good point, there must be some great books on the subject but it's so much easier to post uninformed questions on a forum than it is to read a few good books a few times.
5,711
12,223
If your making close to 850 HP you need to do a lot of upgrading. Glad to here your installing a cage - done right it will stiffen the frame. While you are at it box the frame - it's weak. Weld your rear control arm mounts in (not the greatest from factory) and while your there add rear control arm mount bracing they sell kits. You also need more rear end, sell the 8.5 before you break it. Upgrade your drive shaft, google driveshaft critical RPM - PST has a nice chart.
Where can I find this kit?
Nate,
I'm in the same boat as you. But I'm trying to dial in traction with the tune/traction control. I'd assume you're running a stock ECM, correct? What injectors? I can see dual 044's. Still with the S475? What cam?
We also are boxing the frame, installing a cage and driveshaft loops over the winter. My guess (GUESS ONLY) would be that you're launching too hard on stockish susension.
I will agree with others about the safety end of things, and your tuner. I won't run a 1/4 due to 140+ mph in a G-body without all of the aforementioned upgrades scares the hell out of me. I've tried to datalog through 3rd gear, but I give up at 130mph
Are you datalogging? Do you have any slips or vids?
lilbowtie
3,460
3,965
Canton Mi
Google it - I believe I got mine from Trick Chassis. There are weld in upper and lowers but I couldn't use the lowers with what I did.
Gbodynate
29
6
If any one wants to add me on face book I have vids this sight wont let me post vids fpr one reason or another my name is Nathan friend
Gbodynate
29
6
Nate,
I am running stock ecm swapping to megga squirt and new injectors stock injectors decaped running 80 lbs or somthing like that can't remember npw but I am running 77 lbs fuel pressure to up the flow
Gbodynate
29
6
Testing turbo ls g body no traction. Type that in and you should find a scrap leave first gear and there will be more
