1 RARE T
- Jul 14, 2015
- 274
- 63
My Hellcat will do 195mph stock on stock tires. Where and why are of no concern to a man who only races spec sheets.
You are correct a total of three, they weren't purchased at the dealership I worked at but two were purchased at Crest Buick in Woburn Massachusetts that I know of. One was a GN the other was two tone gray/black T type it looked just liked my brother inlaws car. The third not sure what dealership that came from. There was Nothing special about them just a stock GN and T type that anyone could buy at the dealership. The cars where sent out to have the radio, special lights what ever else they need installed including the illegal tinted windows they had. GM never made special GN or T types for the FBI or Law inforcment it's a myth that's been going around even when I was working on these cars at the dealership back then. If GM was making these special cars for Law enforcement don't you think that every Buick dealer would want a piece of the action including the dealership I worked for. Those cars were used around the city of Boston and a little further north of Boston. One of cars only lasted about three months due to over heating chasing a stolen car on the highway. Other states did use them including mine but they were replaced with the Mustang 5.0I think Massachusetts did get turbo T spec cars, if I recall there is good documentation that supports that.
I don't know exactly when who got what, but with the advent of more "performance" entries with fuel injection in the 80s, that's when GM started limiting speeds. Performance speed-rated street tires were still lagging behind, so with most "peformance" cars, they all seemed to come with Gatorbacks or whatever super-expensive-at-the-time tire would fit. They still weren't good for much over 120 mph or so on the street. I know Iroc-Z had them with 130 mph limiter. I think GNX used them too and I believe they got the same 124 mph limit like the regular GN IIRC.
With regular carbureted G-bodies, they didn't give them enough power to need anything to limit speed.I know 4th gen Camaro SS's were speed limited to 162 mph. Interestingly enough, my ZL1 has 180 limit with sticky Y-rated (186 mph) Goodyears that seemingly last 40 miles before they're worn out. 120+ with the top down on public roads is kinda scary due to the wind as it's easier with the hard top, so I'm not fearing hitting that speed limiter. More afraid of hitting a deer around here at 100+. The SS and 19" or larger wheels/tires on the 5th gens get 155 limiter, and 118 with the standard non-SS V6 18" wheels. I could be mis-remembering some of this, but somehow this is what's sticking in my head.
According to a former Camaro asst. brand manager at GM, the F and Y body limiters were based solely on factory tire combinations. The car itself could sustain more. Although I don't know how. At very high speeds, the rubber nose wants to push in on the early 5th gens and a few racers that exceed 200 mph had splits/cracks at the outer upper headlight opening corners. Not sure if that was just cheesy materials or what. They may have fixed it because I haven't heard much grumblings about it lately.
So seemingly, any limiters they used was based on vehicle high-speed handling, whether it be tires, suspension stability, or a combination of both. F cars always have been corner carvers compared to G-bodies, so the TR/GN body lift and unstable high-speed manners theory, along with the Goodyear tire ratings, likely were factored into the factory limiter settings. The way stock G-body suspensions were, even with F41, I'd be a bit worried taking them past 124 mph out on the roads anyway even if it could do it.![]()
This so called Cop Chip, it didn't come from GM maybe from someone else never heard of it and if it was made by GM dont you think that the parts counter guy would have first hand knowledge of it just like GNX parts.
It's very possible that dealerships in the state you live in had lot boys behind the parts counter.The computer systems in carburetored cars were not complex enough to have nanny features either. Also turbo engines tend to be more fragile than N/A engines. Its why the Ecoboost Taururs Interceptors were less popular than the N/A versions among Police departments. The Ecoboost versions broke down far more often as well as turbo lag caused by the heat soaking from all those idle hours.
I met plenty of parts counter guys at dealerships that didn't know their *ss from a hole in the ground. Plus there is a big difference between a Federal agency and a local town police department. The former generally has far deeper pockets and more sway. Its possible the FBI may have contacted GM to have a few custom parts installed while the MA cops didn't. Different LE agenices and departments don't have identical equipment among each other.
As I said before, the possible differences between an FBI TB and a regular one would be few due to the lack of economy of scale compared to regular 9C1 cars. Again its possible that if these FBI TBs did exist, they likely were only available to the FBI and not to local LE departments, hence the name FBI TBs.
And this sums it up completely right there. Speculation. But it's fun to speculate.For the most part we can only sepculate.
And those chips motorheadmike mentioned...
I've been involved in government purchasing before (not cars, though) and one of the reasons things don't go smooth is all the red tape and wasted funds/time. At least where I was. But regardless of who is doing the actual purchase orders, in a nutshell, they have to be first authorized for quote by the muckity mucks (purchasing did not simply originate requests for other departments), and then final purchasing orders had to be signed off by a management level of whatever department with authority to spend. And usually that meant (inbox -> usually signed without reading much more than the bottom line -> outbox). Then they could report to THEIR boss that whatever it was is now on order so they could check their box. When it came to tools/parts, etc., many times the engineering groups would spec out a part, and providing it wasn't classified and quality control approved, the specs were sent to the prospective manufacturer for quote. This could include drawings and spec sheets, or just a matter of something available on the shelf, like sending a request to a screwdriver company for 5,000 stubby #2 Phillips head screwdrivers, for example. Classified stuff was handled at a completely different level. Most of the purchasing groups normally weren't experts on everything they're buying, but they knew HOW to purchase the items. Procuring the turbo Buicks would be simple enough. Getting all these "secret squirrel" laundry list add-ons that nobody else could get? Nah, can't see that happening, although it's always a possibility. Seriously doubt they'd know what was even available if it wasn't told to them.
What's taught in the colleges is the ideal streamlined point A to B situations. You know, how it SHOULD work. In the U.S. government real life, it's more of a twilight zone. Redundancy is built-in for some reason. You would like to think that most of them would know what they're doing, and some are pretty good. Sadly, that isn't always the case. If they get it right and re-order, then it's a matter of copy and paste which becomes way easier. But if they have to reinvent a wheel? It's normally a sh*t show with layers of stupidity thrown in. Maybe it's got better, I don't know.
But as stated, we can only speculate how all the purchasing of these Regals were actually done. It would be interesting to see that layer of onion, though.
