Other plans will likely include;
1. PAINT since only the roof and rear quarter panels has nice glossy paint, the rest is pretty sunbaked and need to be repainted. The Landau vynil roof has pockmarks in it like it was hail damaged so i need at a minimum to plastidip that just to waterproof it if not redo vinyl entirely or eliminate entirely and paint at same time as everything else.
2. then i imagine a new rearend or gearset is gonna be wanted since the stock gears are either 2.14 or 2.56 granny gears and 1 tire frier/no posi.
But so far a performance drop in rearend from a performance G-body that fits doesnt seem to exist anywheres close to saskatoon, so may have to go Ford 8.8/9 inch swap and make fit but dont know much about that as of yet.
3. then theres the spaghetti soft frame and suspension that could use lowering springs for looks and lower center of gravity, beefier sway bars and shocks although it still rides nice despite leaking worn out shocks, frame stiffeners, shock tower braces,
4 then a new wheel n tire package mostly for looks but also a bit tighter handling. it came with 205/75R14 from factory and has aftermarkets from that era that are 205 65/R15s. If i goto 205/50R16s it will share same size tires as my other car but i might goto 17s
I dont actually have any pics right now but my profile pic is kinda what i want it to look like.
