monte olrac excellant schemetic! But since I'm not much at electrical wiring, I have a question.
In the low beam wiring going into the relays, it shows a lt green wire as not used. My question is do the low beam lights go out when the high beams are turned on or are all 4 lights on when the high beams are on?
I guess, after a bit more thinking (my mind is wore out from work today ... :? ) that since the low beams stay on in stock confiruration that they would also stay on this way too. Correct?
So, with high beams on, it *should* still have all 4 headlights lit up?
