And it’s funny bc iAsked the rep could iRun it to 5/16 and cut the valve, then run the vent line to the 1/4 and add my external ROV. They never wrote back lol. I’m going to put an external checc valve between regulator and rails. It started so well when that pressure held lol.I just had two ports on the sender I had so I used the 5/16 vapor return that has the check valve and line reducer. I didn't realised that valve was there and that caused the pressure to sit at 80 lbs. I removed the sender and cut the pipe so it was an open 5/16" port. After that the pressure was fine at 43 lbs and I can regulate it up or down from there if needed, after that I changed it to GN tank with with the in tank pump
