Thank you!!!!
750cfm is just fine for that engine. I've run a 750 DP on very mild 350s, and they work great. Street driven.
But if the idle transfer slots are uncovered by having the throttle plates open (idle speed screw) too far the main circuit starts to feed fuel. Having the plates open (idle speed screw) too far is a common problem with LOTS of Cam & many guys end up idling with the main circuit starting to engage. And if that's the case a blown power valve would affect the fuel going into the engine at idle. I have recently learned that the optimum position for the throttle plates (at idle), primary side is with the minimum exposure of the transfer slot. This helps light throttle transition when you move from a dead stop. So you ask how do I get my idle speed up? By adjusting the secondary plates to desired idle speed. Find secondary idle speed screw under base by secondary throttle shaft, passenger side. Anyway I noticed that OP hasn't even chimed back in, so this conversation is just expanding our education. Thank you Ribbedroof for correcting me, as I wasn't elaborate enough in my explanation. Ole Bob.Guys, a power valve has nothing to do with idle. Even if it's blown, the idle circuit restrictions will not allow all that fuel to enter the intake.
install an air/fuel wideband gauge and let me know what the numbers are
Sounds like an expensive way to prove something I already know works. All of my 350s have had a 750dp on top. If you want to buy me one I'd be happy to tell you.
More over, if you want to fund a way to set up two identical cars and engines, with different carbs, you choose 625-650cfm in whatever configuration you think is good and I'll pick a 750 DP, I'll run the same efficiency as you but faster.
