I would check a spark plug and see if they're black. That 750 you tried on it could have fouled the plugs causing it to run rough. An over rich bigger carb usually makes them seem to run like hell till the plugs get fouled. If you do not have a vacuum gauge, you cannot properly tune a Holley. Gauges are cheap. (around $15). You set the air bleeds to the highest reading on the gauge. After car is warmed up, put it in gear, gauge on manifold vacuum, whatever your reading is, split the number in half and that's the proper power valve size for your engine. To check primary jet size you must be driving normal above 35mph on a less populated side road and kill the engine, check the plug, and jet up or down depending on how they look. Only go 2 sizes at a time on jet size. You cannot just bolt on a new carb and expect it to perform at its best. Every engine is different and you have to tailor it. All the above tuning info depends on your timing being set correctly first. If the timings was incorrect, the carb tune will be too. To drain your carb float bowl on the car, I like to use a spray paint cap. Hold the cap under one of the bottom float bowl bolts and loosen the bolt and unthread it a bit. The gas runs into the cup and not all over the engine.
