Do you have a fuel pressure gauge? Could be simply running out of fuel, could be valve float, or yes still could be on the lean side at the top end
Fox80 said:Do you have a fuel pressure gauge? Could be simply running out of fuel, could be valve float, or yes still could be on the lean side at the top end
Fox80 said:Ok should eliminate the pump being a problem, could still be the pickup sock so a gauge should still help eliminate the fuel system as a whole
Fox80 said:It is restrictive, but it doesn't require much fuel to feed a 125hp motor that all these cars came with, you are now asking more out of the system so it will need some modifications
