lilbowtie said:Have you tried the plugs yet?? No 450 hp isn't too much but you need the right parts and those parts all have to work together. Cam, intake, carb, torque converter, rear end, have to be matched for your combo. You are currently set up for bottom end and your package pretty much matches with the exception of the big heads. Your engine isn't much above stock; you have a point more compression and a little more cam so right now 450 hp is a stretch.
The plugs are brand new champion RC12YC. Previously I had an NGK racing plugs in which were recommended on the head spec card. No difference between either.
