Holley G-Body LS swap infotainment thread.
Saving for updates. About to start on an LS3/TR6060 swap in my Regal using the Holley system.
Do you or anyone know if these mounts lower or raise the engine? I’ve heard both from different people/websites
Did you have any issues with the tunnel when fitting the trans? Pretty soon I am wanting to use these same parts with a T56.
My understanding is it keeps the motor pretty much in the original stock location, but low enough that most stock oil pans dont work (lower than most swap mounts). I had no clearance issues with the 4L80e, you can even easily get the trans cooler lines on and off as long as you have 90s on the trans side. Even with the 1 7/8" headers there are no clearance issues anywhere.
Thanks for sharing. Good info.
Reactions: Northernregal
Did you use the truck accessories? Any clearance issues with the PSP pulley?
