Homemade Bracing
The tail sections of the frame that are behind the spring pocket are flimsy and they can use all of the help you can give them. I made one like Abbey described several times - they definitely help.
About every aftermarket support available works and is not a waste of money if you have any plan to stiffen the car. The rear seat brace and rear spring tower supports are definitely a good product as well.
If you intend to do any racing, then the weld supports in the rear upper a-arm mounts are a must as well. And the links that attach the lower and upper mount bolts together help too. I just finished reinstalling my rear and I haven’t bent anything too severely yet lol - I have all of the rear bracing that can be purchased and I put the wood to back end more than most that don’t have a full tube chassis.
Well, I'm building my car for autocross so hopefully I won't have any issues from too much power
I made my own rear seat cross bracing. I do have the factory stampings from another car that I plan to trim and install to look like the factory stamped brace.
That looks really good but I have an El Camino
I made my own rear frame brace, aka 'Jeff bar", out ofvsquare tubing. I drilled 3 holes instead of the usually two to prevent rotation on the side that has two bumper mount bolt holes on the bottom.
This topic has caused flaming on some forums regarding G bodies. Some guys oddly really hate add on bracing.
can't argue with a man that carries the wheels on the regular
I made all of the braces on my Monte and the fender to core support, GP bar and rear brace for the Regal.
The fender to core support braces I used 3/4" EMT and made a crimper for my press to make a nice end on it.
The jounce and GP bars I made out of Rigid 3/4" EMT which is about twice as thick as the factory bars and I bent those in my HF tubing bender and also crimped the ends.
And for the rear bars I used 1-3/4" roll bar tubing with my Monte's being welded in and my Regal's I made as a bolt in.View attachment 243979
Very nice job on crimping the ends. That detail make them look like a manufactured product. I think most would just squash the ends flat in press or vice and call it a day.
May I ask how you made the dies?
Get the beefiest sway bars that you can find - the stock dinky ones won't cut it. Also a proper alignment with the correct sized tires will make a night and day difference. Plenty of of camber and 1.5-3 degres of pinion angle will help a ton for cornering and traction.
What tires are you running?
I'm running Nitto 555s. 245/35/17 front and 275/40/17 rear.
So far, the biggest front bar I can find is the Belltech. But my next major mod is gonna be coilovers. The front is sitting about an inch higher than the rear, since I'm running an aluminum block ls1 on stock springs.
