That's the plan. Already have them in my shopping cart lolBuy the cheapest shocks you can find. Should be able to get a pair for $30 or so on closeout
Bought a pair of the cheapest monroe shocks oreilly had for a truck I sold,waste of time,originals were leaking bounced less with the leaky shocks,spent $30 per shock more, huge difference.Buy the cheapest shocks you can find. Should be able to get a pair for $30 or so on closeout
That's probably the case. I know it does rub a little bit. I just gotta figure out why it sits lower on that sideCould the side that is sitting lower be rubbing the fender well on dips, causing a drag condition to turn the steering wheel? Before you swap out those dampers measure your front fender heights. Curious where it is sitting and if it's leaning.
I plan on checking everything out - hopefully tonight - when I remove the shocks. I ordered nice new Monroe's to replace the cheapy O'Reilly's I have in there now. I know I said I'd be going to coil overs but who knows if that will happen yet. Things change.
Once I get the shocks changed I will try to do an alignment since I'll have the camber/caster gauge by then. This is all depending on what I find during the inspection.
