Hot light wont turn off
Test to make sure the Ohms values are correct but it could be possible it's a factory defect.
A factory defect? The car is 41 years old... I have owned it for 5 years. And this just started when the thermostat went bad 2 weeks ago.
I was understanding the temp switch was new. If it is the original it might just be time for a new one.
A lot of the new stuff is complete junk and DOA out of the box
Did you use any sealant on the threads?
Reactions: HeadKnock
unplug the wire at the sender, if the light stays on then you have a problem with the wire like fleming442 suggested
