According to the Chilton manual the wire is hotI thought they grounded to turn the light on. Sounds more like you pinched the wire in the manifold.
Its hotunplug the wire at the sender, if the light stays on then you have a problem with the wire like fleming442 suggested
I think... Check it outAccording to the Chilton manual the wire is hot
Yes but it has a clip on top for the light not a guage... Like a speakerdoes your sender look like this?
Yesif it is a single wire connector it would not be hot and your PDF diagram shows the dark green wire is not hot. When you unplug the wire to the sender does the temperature light stay on?
