How to change ignition switch?
Is it possible to remove the locking mechanism inside the steering column & it still function properly?
tc1959 said:
Why would you not want to lock your car ?
I'm thinking about doing some custom work... When I'm not in the car it will be secured in my garage so I'm not worried about anyone stealing it.
Well I got under there and figured how to drop the column. It was really easy to swap out the switch.....
And it worked great! It starts up like a 2010 now. The old one didn't look burn't, but it looked like it had been dipped in salt water or something :lol: But I'm really happy with my car now. I wanted to set it on fire yesterday.
Thanks for your help on this one...
  • Optimistic
Reactions: Rus
so is it just the 4 bolts that hold the steering columm up ?
I took out the bolts that held the piece around the column on the firewall. Then the ones that hold the column up to the dash.
are they hard to reach the ones on the fire wall ??
if you just drop the bolts that hang the column up you can easily get to the ignition switch....when you change it make sure it's adjusted properly before you put the column back in it's place
aight thanks
you have two 7 mm bolts, (I think thats the size) one in front and one behind of the high beam switch and then their's a philips screw to remove the ignition switch
