Well tomorrow I plan on changing out my ignition switch. I picked one up today for nine bucks, but I have been told its hard to install. What all do I have to do to change it out? I have heard that I have to drop the steering column, and could possibly mess a lot of stuff up. The problem I am having is that when I turn my key, my car won't start. It has been a problem for about the last six months. I drive the car everyday. It used to only do it every once in a while. It is starting to get more, and more common. I would turn the key, and nothing... Try it a couple more times, and then it would fire up. The other day, I had to turn the key like 20 times to get it to start up. Then it did fine for a few days, and now I am not starting at all. I don't really want to be stranded anywhere, so I wana get it swapped out.
Over the past weeks I have replaced the key cylinder, positive battery cable, negative cable, and the starter itself. Figured I would do the actual switch next.
So what do I have to do to swap it out?
