Romaniac said:This auto th350 has over 150k on it, so Im planning to change the filter and ATF in the entire system. I've heard it's necessary to do this on automatic transmissions at least every 150k. How do I do come about doing this properly? Thanks everyone
At the dealership we call that a wallet flush. :wink because that's all it's good for, removing cash from your wallet. )565bbchevy said:If you can find a local place that has a trans fluid exchange machine (don't know the exact name) they plumb it into your trans line and they fill the machine with new fluid and you start your car and your trans forces all the old fluid out and pushes the new fluid in.
I had it done on my Lincoln about 10 years ago and it worked great and the trans still works perfectly since it also puts new fluid in the convertor, cooler, etc. instead of just draining the trans.
It's been awhile but I believe they changed the filter first and filled with new fluid before hooking it up to the machine.
tc1959 said:At the dealership we call that a wallet flush. :wink because that's all it's good for, removing cash from your wallet. )565bbchevy said:If you can find a local place that has a trans fluid exchange machine (don't know the exact name) they plumb it into your trans line and they fill the machine with new fluid and you start your car and your trans forces all the old fluid out and pushes the new fluid in.
Romaniac said:Sweet, thanks everyone. The car aint in running condition, but when It is that sure sounds like the way to do it yourself!
How do I know which one is the incoming trans cooler line?[ you can generally tell buy how they route to the trans, but since you're gonna be cleaning out both lines & they'll both be unhooked anyways, you'll know which one it is when you start the car.
