How to remove rubberized undercoating under car
dickeymoore
947
117
Atlanta,Georgia
I need to remove my emergency brake cables and the person I bought the car for used rubberized undercoating and he sprayed all the cables and nuts what can I do to get the cables and nut lose what is a good way to remove the undercoating from the cables so I can get them off can I use aircraft stripper or something similar?THANKS
Nov 4, 2012
6,085
13,052
This is (one reason) why I'm not a fan of rubberized undercoating. Brake cleaner should soften it up, but aircraft stripper will probably work better. In either case prepare for a mess.
Clutch
5,191
10,928
Brick NJ
Be very careful don't get it in your eyes and remember it will effect anything it touches
Streetbu
Know it all, that doesn't
3,800
11,899
Central NY
Kerosene, a paint brush, and a HUGE mess.
  • Informative
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
Have you checked to see if it would peel off. He probably didn't prep or clean the surfaces so it shouldn't have bonded to the surfaces
  • Informative
old80cs
648
2,160
Massachusetts
Propane torch (to soften it up) and a scraper, did my whole chassis that way. Replaced the rotted out floor so I didn't have to scrape the underside much. Be careful it will catch fire easily.
ed1948
1,286
1,613
Quinte West, Ontario
I would only remove whatever is loose with a wire brush or wheel. It does have a limited life on most surfaces. A common use is to hide rust.
I have used it in the past in wheel wells and rockers and found it to be quite durable if the surface was clean and rust free.
